| To get an opinion. My car is complete minus my clutch being bled (and oil pump primed). Has Z1 one piece SS clutch line I attempted to bleed the clutch but can't get it to improve. Never had an issue before but never bled a vacuum assisted clutch. So it has light resistance the first 3/4 of travel, then it feel the clutch disengaging, but just the last little bit. Not enough to fully disengage. I bled it several times and it never improved, including manually bleeding the slave itself (compressing it to ensure no air). I can see the slave pushing the fork. It rests against it disengaged, pushed out maybe a little less than an inch. The slave piston feels pretty loose inside the cylinder, which may be a sign it's shot? Also, when I open the bleed screw without pressing the pedal (reservoir open) the fluid flows out and empties the reservoir, although I don't know if that is normal or not either. So, any ideas? I figure either: -needs more bleeding? -bad master -bad slave -both?
------------------------------------------------------------------ 1992 300ZX NA 5 Sp (Dead) 1990 300ZX NA Auto 2+2 (Dead) 1990 300ZX TT 5 Sp (Building) 2004 G35 Sport 6MT (DD) |
